pankajsingh
Mar 11, 2022Aspirant
RBR50/RBS50 Moving from one router to another
I already have an existing RBR50 (call it MASTER) and RBS50 (call it SATELLITE-1). I needed to have another satellite RBS50 to my network. I purchased another RBS50 (call it eBaySatellite) and it als...
- Mar 11, 2022
If you hardwire into it, can you run it through the sync process?
CrimpOn
Mar 11, 2022Guru - Experienced User
pankajsingh wrote:
What I am trying to do is make eBaySatellite connect to MASTER as another satellite. I sync'ed it using buttons, using browser, tried resetting... Nothing seems to work.
Was the reset button on the new satellite (inside that tiny hole) held until the power LED turned amber, and then began to flash?
(this often takes10-12 seconds)
I agree that "it's seems logical" to have the same firmware release on both router and satellite. There are plenty of posts on the forum from users where this is not the case. And, the original Orbi sync's with a host of satellites that cannot possibly have the same firmware version (RBW30, RBS40V, RBS50Y, for example). Once the new satellite gets connected to the existing router, it is probably a good idea to ensure that they all have the same firmware release.
