pankajsingh
Mar 11, 2022Aspirant
RBR50/RBS50 Moving from one router to another
I already have an existing RBR50 (call it MASTER) and RBS50 (call it SATELLITE-1). I needed to have another satellite RBS50 to my network. I purchased another RBS50 (call it eBaySatellite) and it als...
- Mar 11, 2022
If you hardwire into it, can you run it through the sync process?
pankajsingh
Yes actually, the power button did flash amber. What never happened though is - the orbi satellite never went solid white. That is what the instruction expects to happen
Mar 11, 2022Guru - Experienced User
- pankajsinghMar 11, 2022Aspirant
plemans wrote:If you hardwire into it, can you run it through the sync process?
I can try. You mean hard-wire the new satellite to the RBR50?
This actually worked. Not sure if hard-wiring helped OR the fact that I kept trying till it worked. The white light finally disappeared. One unique thing this time was that there was no ring light
