JBinIL
Mar 23, 2019Star
RBR50/RBS50/RBSS50Y - Auto/manually setting wifi's devices' preferred SSID IP addresses needed!
I have a large three-level home on a 3.5-acre propety. I have one Orbio main router (RBR50), two indoor satellites (RBS50), and two outdoor satellites (RBS50Y. The main router and all indoor and outd...
JBinIL
Mar 24, 2019Star
Ekhalil: Thanks for your thoughtful response,
With the introducton of mesh-based networking, where the same SSID is used throughout the network across multiple devices (the main router and its satellites), mesh-based networks simply have to have a minimum amount of administrative controls necessary to prevent absurd (weak/extremely slow) wifi connections. Without ths basic wifi connection management capability, much of the advantages of using a mesh-based network is defeated.
If Netgear's Orbi system does not have the ability to manage the router/satellite wifi devices' connect to, then why do (some) wifi devices on my network sometimes switch to another Orbi router/satellite with the same SSID after a few days?
Subject to wifi devices' roaming-related constraints, any centralized - and reliable - approach to managing wifi devices' wifi connections would suffice. For example, can Netgear's centralized and web-accessible administrative user interface be enhanced to either:
1. Provide wifi administrators with the ability to add a list of excluded/ignored wifi devices (e.g. by MAC address?) to each router/satellite so that, when a wifi device attempts to connect to an inappropriate router/satellite that uses the same SSID, but has a poor signal and/or connection speed, that the specified router/satellite simply ignores the connection request, thus allowing the closer/faster wifi device to connect to a router/satellite with a stronger/faster signal?
2. Redirect the wifi device's weak/slow connection request to a router/satellite to another user-specified wifi device that is more appropriate?
While Netgear may not have full control over wifi devices' roaming processes, it would seem that a centralized method for managing this is both possible and essential.
I will be curious what you and others' responses are.
Thanks again.
ekhalil
Mar 24, 2019Master
As mentioned earlier, in Wifi standards control of roaming is solely given to the device ad not to the AP.
The only things that the AP can do is as I mentioend to help -not force- the device to choose. This is also an advanced procedure that needs to be carefully done, so a detailed radio network audit is needed to make this possible, otherwise, making those settings randomly can very much cause devices to be randomly disconnected from wifi. I think this is exactly why Netgear and other vendors is choosing not to implement such procedures in consumer products like Orbi. This is usually imlemented in Enterprise solutions.
