trigger_cut
Jan 30, 2025Aspirant
RBR50's bricking?
Our RBR50 router seems to have bricked itself overnight. The satellite seems fine, but the router will not show any LED rings, and doesn't respond to the factory reset button. Here's the weird part...
michaelkenward
Jan 31, 2025Guru - Experienced User
What modem/gateway/ONT is the router connected to?
A few things to try to pin down the problem.
Have you checked that this is delivering a connection?
Have you tried different power adapters?
Have you rebooted the network in the expected order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Just another user with time on their hands.
