Samoussa
Mar 24, 2021Aspirant
RBR50v1 vs RBR50v2 power adapters
Hello, I can only see few differences between RBR50 v1 and v2 and I noticed a difference in the provided power adapters. Indeed, for v1, we get a 12V 3.5A and for v2, we get a 12V 2.5A according ...
- Mar 24, 2021
There tends to be process improvements between versions as well as v2 removed the usb.
This tends to drop power demands which is why you see lower power needs on v2.
Can you use a v2 power adapter for a v1? You can use it but if it needs more power than the 30 watts and the power supply doesn't provide enough, you'll get drops/issues/reboots. You might be fine but I wouldn't do it unless you had no other option.
Samoussa
Hello,
Thank you for your answer. I have all my electric network converging into a panel with limited depth, therefore the current power adapter of the v1 takes too much space and I can't shut the door panel :/
That's why I wanted to replace the power supply of the v1 with another one which could fit better. What if I take a 12V 3A power supply ? Would this be more suitable ?
Regards
