jhoff909's avatar
jhoff909
Apprentice
May 19, 2020
RBR50v1 vs RBR50v2
Anyone know the difference between the RBR50 and the RBR50v2?  I can see that the original has a USB port and the v2 does not but is there anything else?
Also, can they interoperate?  I have an RBR50v2 and an RBS50v2 - I assume I can add an RBS50v1?
    Besides the USB port, the v2 router has less storage.  No one has ever mentioned problems connecting a v1 satellite to a v2 router.
  • CrimpOn's avatar
    CrimpOn
    • jhoff909's avatar
      jhoff909
      Apprentice
      So there are no pluses to the V2?  I'm looking for an RBS50 - if I have the opportunity to buy a V1 RBR50/RBS50 pair for a decent price, it might be worth it to swap out my RBR50v2?
      • FURRYe38's avatar
        IF yoru wanting the V1 for the USB port and USB drive functionality, v1 doesn't support USB drives on the USB port FYI. Not alot you can do with the USB port. :smileyfrustrated:
