itsXtrip
Aug 20, 2021Aspirant
RBR50v2 --> RBR96 (AP Mode) Same SSID
Hello all and thanks in advance for taking the time to read my post. I have searched a few other posts that have slightly similiar issues as mine, but with a few variables and not the same solution. ...
itsXtrip
As I understand it, the client purchased an Orbi kit (router + two sattelites) for inside the home. At a later date, he acquired another Orbi unit (model # on back says RBR96)
Originally, the RBR96 was in router mode and hardwired back to RBR50 in the main house. There were issues as one router was plugged into another router and broadcasting two networks.
I configured the RBR86 into AP mode.
The only setting I changed on the RBR50 was set the DNS to 8.8.8.8 & 8.8.4.4
CrimpOn
Aug 20, 2021Guru - Experienced User
With the second Orbi in AP mode, all of the Sonos devices will get IP's in the same subnet. Placing Sonos units into groups is a question for Sonos. (I understand they are 'touchy' or was it 'tempermental'?)
But, yes, there is no reason both Orbi units cannot have exactly the same WiFi SSID/password. They will not magically become one unified network, but there is no harm in doing so.
- FURRYe38Aug 21, 2021Guru - Experienced User
Would you confirm that the RBR96 model number please?
Just to be sure of the RBR96 as this is NOT a valid Orbi model #.- itsXtripAug 21, 2021AspirantMy apologies - the RBR96 that I mentioned is actually an RBR50
Thank you for confirming.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You could use same SSID, Just be sure that channels between the 1st RBR and 2nd RBR are far appart. Channel 1 and 36 for the 1st RBR and Channel 11 and 48 for the 2nd RBR in AP mode.
Distance between the RBRs should be 30 feet or more. If you run into odd problems, you might turn down the power output of the 2nd RBR in AP mode from 100% to 50 or 25%.
