indinsg
Mar 19, 2021Aspirant
RBR50v2 - Issues post Firmware update
Hi, Just did a firware update and having issues connecting to the Orbi app. It asks for the admin password, which i entered with the default password. Does not go in. Tried resetting the admin passw...
vajim
Mar 20, 2021Master
The default Gateway IP address of your Orbi is 192.168.1.1.
indinsg
Mar 21, 2021Aspirant
Cant ping 192.168.1.1 when I connect to the WiFi on my desktop. Attached network configuration from my mac.
- joejoethedogMar 27, 2021Tutor
Not sure if you've fixed this yet, but your default network on the Orbi is 10.0.0.X, so your Orbi router should be at 10.0.0.1 per your screenshot. (This is non-default, btw, but it is ok.) Also, going to orbilogin.com when connected to the Orbi wifi is correct, since Orbi does the DNS translation to the correct IP address of the router.
If you don't know your secruity questions, then you will need to do a factory reset. Sorry! https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
