ajredaelli
Jun 01, 2020Tutor
RBR50v2 - No Internet
I just bought the RBR50v2 Router with a Satellite. I went ahead and setup the router. I have a strong signal, however, I wasn't able to connect with my phone. When I tried to connect my Roku and the ...
Jun 02, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
ajredaelli
Jun 03, 2020Tutor
I will check into all of these. I can't right now because I work from home and I am not connected to the Orbi. Not sure about the firmware. It's about 1900 Sq. Ft home. Not connected to the satellite yet. When I checked it I was literally next to the Orbi and the TV was just about 20 feet away.
- FURRYe38Jun 03, 2020Guru - Experienced User
Ok, check the suggestions when you get a chance.
- ajredaelliJun 03, 2020Tutor
Will do - thanks!
