awroehm
Jan 06, 2021Aspirant
RBR50v2 Admin password not working
No1Mportnt
Jan 06, 2021Luminary
What happens when you try to enter the password? Please provide as much information as possible.
- awroehmJan 06, 2021Aspirant
just said. didn't work. try again...and again....i tried 'forgot password' and i get error code 404
thx
exact words. "login failed. Please re-enter the correct admin password for your NETGEAR router".
- plemansJan 06, 2021Guru - Experienced User
If the password is wrong/doesn't work and you're unable to complete the password recovery option (or didn't set it up), then you'd need to factory reset to get back in.
Push and hold reset for 7-15 seconds while its powered on.
still does'nt work. same error message
