awroehm
Jan 06, 2021Aspirant
RBR50v2 Admin password not working
No1Mportnt
Jan 06, 2021Luminary
What happens when you try to enter the password? Please provide as much information as possible.
awroehm
just said. didn't work. try again...and again....i tried 'forgot password' and i get error code 404
thx
- awroehmJan 06, 2021Aspirant
exact words. "login failed. Please re-enter the correct admin password for your NETGEAR router".
- plemansJan 06, 2021Guru - Experienced User
If the password is wrong/doesn't work and you're unable to complete the password recovery option (or didn't set it up), then you'd need to factory reset to get back in.
Push and hold reset for 7-15 seconds while its powered on.
