Jan_H
May 06, 2024Aspirant
RBR50V2 blocks one of the satellites
Hi, I have a RBR50v2 with 2 satellites RBS50v2. I have acces control enabled for year now with no problems. I upgraded the firmware of the router and satellites to the latest (2.7.5.4) a couple of...
Jan_H
The strange thing is that it shows up on the connected devices page. But when i visit the satellite itself by the ip address is says that netgear armor has blocked that device.
I can visist and login on the other satellite.
May 06, 2024Guru - Experienced User
What happens if you disable Armor on the Orbi app?
- Jan_HMay 06, 2024AspirantTried that and the satellite is still blocked.
- FURRYe38May 06, 2024Guru - Experienced User
Did you power OFF the system for 1 minute then back ON after disabling Armor in Orbi app?
I just tried that last night and that seems to have done the trick. I have enabled access control again as well and this morning it is still ok.
I will keep you posted if it stays this way đ
Tnx for the help so far
