Patientman
Apr 19, 2024Aspirant
RBR50v2 cannot connect to Tesla Wall Charger
I have a RBR50v2 Router with 2 x RBS50v2 satellites. I recently added a RBS50 satellite to strengthen the signal at the front of the house. Router Firmware Version V2.7.4.24 I have had a Tesla Gen ...
- Apr 19, 2024
IF this charger device see the Orbi or TP-Link Wi-Fi signals, then you'll need to contact Tesla for help and support regarding there product.
Orbi is behind on FW as well:
Something to try and see if this changing anything.
Patientman
Thanks, but it does not see my network and Tesla have looked at it but found no fault.
Apr 19, 2024Guru - Experienced User
Try enabling the Guest Network on the RBR. Give it a simple SSID name, say like RBR50-GuestNetwork and set the password to Password123. WPA2 and AES. Does it see this SSID name? If not, something Telsa will need to help out with.
I presume all other wireless devices see the network name?
- CrimpOnApr 19, 2024Guru - Experienced User
Like many Internet of Things (IoT) devices, it appears that the Tesla device creates its own WiFi hot spot and the smartphone setting things up first connects to the Tesla and then tells the Tesla to connect to the local WiFi system.
https://teslamotorsclub.com/tmc/threads/connecting-wall-charger-to-wifi.226513/
I'm assuming that when standing very close to the Tesla device, the smartphone detects both the Orbi WiFi signal and that TP-Link Extender WiFi signal?
- PatientmanApr 26, 2024Aspirant
I have already tried all the suggestions you gave me, and gone through those with Tesla as well but the charger would not see any of my SSIDs.
HOWEVER - I downloaded the Firmware update from the link given by FURRYe38 and spent about an hour manually updating the router and satellites and now I have successfully connected to the TP-Link extender which I added. I can now control the charger from the Tesla app.
- FURRYe38Apr 26, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
