Answer42's avatar
Answer42
RBR50v2 Cisco ASA5505 ACL Rules
I have recently purchased the ORBI system.  I have a Cisco ASA 5505 and i am unable to manage it or take advantange of additional services such as parrental controls.  I have been digging through the ASA loggs and located the Circle IP address 45.33.13.155.  What other TCP and UDP addresses and ports do i need to allow in order to make this system fully functional?
  • FURRYe38's avatar
    I recommend if this applicance device is in front of your RBR, then you should configure the RBR for AP mode.
    This could be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #3.
    I see the applicance devices is only rates for 100Mbps. The Orbi system is rated for 1000Mpbs. So the Cisco would be a bottle neck in peformances.
    https://www.cisco.com/c/en/us/support/security/asa-5505-adaptive-security-appliance/model.html
    I alos see it's on Cisco's EOL list.
    Release Date 31-AUG-2006
    End-of-Sale Date 25-AUG-2017
    End-of-Support Date 31-AUG-2022
    14 year old product. You might want to consider getting into something newer and something that supports 1000Mpbs on the LAN
    • Answer42's avatar
      Answer42
      Thank you for the response. I will go into more detail about my network.
      I have a Motorola docsys 3.0 modem with a 100mb internet connection. I have an outside vlan for the modem, an inside vlan for the physically connected computers and finally I have a wireless vlan for the ORBI.
      The problem i am having is that the Cisco ASA is blocking access to all the additional resources such as Circle, Netgear Armor, etc. I am also unable to manage the network remotely either.
      I need to create firewall rules in my ASA to allow that connectivity to reach my wireless vlan and the ip address of the ORBI. It seems there is some kind of cloud service the device communicates with in order to manage it remotely. What are the IP addresses and ports associated to all the additional features?
      I have internet access working, but if the outside services attempt to communicate with the ORBI directly they are denied.
      Identified information:
      Circle IP Address: 45.33.13.155 - reverse lookup download.meetcicle.com - TCP port 443, https
      Bit Defender: 34.202.127.134 - reverse lookup nimbus.bitdefender.net - TCP port 443. https
      Netgear Time Sever: 209.249.181.91 - reverse lookup time-b.netgear.com - UDP port 123
                         Netgear also has several IP, the range is 209.249.181.0 - 209.249.181.127
      Do we know if Netgear uses Amazon CloudFront for these services?
