jeyroc888
Apr 24, 2023Tutor
RBR50v2 does not allow some devices to connect to the Internet
I just installed a RBR50v2 and it was a disappointment. I will be greatly obliged if anyone can help me out. I had to set up the system with a phone (what a joke!, this should have altered me) an...
- Apr 27, 2023
The point is really moot. As I said, I can get to the router by going to 192.168.1.1.
Thanks for the response.
Apr 25, 2023Guru - Experienced User
1. What modem/gateway is the router connected to?
2. what firmware is on the router and the satellite?
For next time, you don't have to use your phone. When you first connect to the router with a pc and go to its ip address or the routerlogin address it'll say "we recommend......app" blah blah blah but if you scroll to the bottom of the page, there's a link you can click to go through the browser based setup. Works much better and my preferred way of setup.
- jeyroc888Apr 25, 2023Tutor
I *did* connect with my phone. The network came up. I plugged my PC and Vonage (VIOP phone) modem directly into one of the satellites. They work.
I then got two Android phones to connect to the network without issues.
But the following devices can detect the network, can connect, but there is no Internet access:
Two Windows 10 laptops
Two iPhones
One iPad
The router is whatever Greenlight (the local fibre optic ISP) installed.
How do I find the firmware? The stupid phone app said it was checking for new firmware, could not find it after 5 attempts and so I bypassed that part of the set up.
Futzing around with the phone app tells me the following:
Firmware Ver: v2.7.3.22
Thanks for the hint re PC login. It works now (did not do so before).
Interestingly, it lists just the 4 devices mentioned before (two Samsung phones and the wired PC and Vonage modem). No mention of the other devices.
However, they do show up when I get to "Access Control" on the PC web interface.
Partial success! I did manage to get the iPhones and iPad by simply selecting them from the list of unconnected devices and hitting "Add".
The laptops remain to be connected ... it did not work and then I realised that they are listed as "Wired" devices. I need to change that.
No time now ..... got to go. Will update later.
I am using the web interface on the PC now. Phew! What a relief.
- plemansApr 25, 2023Guru - Experienced User
What gateway is it from greenlight?
Sometimes they install ONT's and sometimes gateways with their own router built in.
All done!!!!
I am still not sure how it all worked out, but I found the key in "Access Control" page on the web interface. I had to delete some of the unconnected devices and then add them on again. Somehow, that seems to have worked.
All devices are now connected and everything appears to be fine.
Still disappointed with Netgear's instructions for set up -- they could have added a set up guide a few pages long. It would have been so much easier than monkeying around with the phone app.
Thanks for the hints, plemans.
- FURRYe38Apr 26, 2023Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System- jeyroc888Apr 26, 2023Tutor
Thanks for the hint. Given that I cannot quite remember the things I monkeyed with, it is very good advice!!
Another thing I do not get is that orbilogin.net never works. It takes to me to Netgear's homepage. Why do they not say that one can get to the router by using 192.168.1.1?
