rjskrn
Sep 14, 2023Aspirant
RBR50v2 doesn't turn ON. Power LED doesn't light up.
My RBR50V2 was working fine until I plugged out the WAN cable. Reinserting the WAN kicked the power LED OFF. Turning off and on the router several times, resetting didn't revive the dead router. Trie...
michaelkenward
Sep 16, 2023Guru - Experienced User
If the power LED won't light, that could be a sign of a dead router.
First, though, check that the power router's adapter isn't the problem.
- rjskrnSep 18, 2023Aspirant
Checked the output voltage of adapter, it was somewhere around 12.3V. The same adaptor works fine with the satellite.
Where can we find PCB troubleshooting guide?
- michaelkenwardSep 18, 2023Guru - Experienced User
Confirms that the adapter isn't the problem.
Can't help on that front. It isn't the sort of thing that Netgear is likely to share.
- rjskrnSep 22, 2023Aspirant
Alright. Thanks.
