Randyvan
Aug 15, 2020Aspirant
RBR50v2 download and upload max Internet speeds
What is the max internet speed for uploading and downloading I should be able to pass through this router? I'm presently getting: Download 48.73 Mbps Upload 2.35 Mbps Ping 1ms I'm suppos...
- Aug 15, 2020
I put on wired system and speed tested as follows:
Ping 2
Download 49.21
Upload 2.11
Seemed about the same
Aug 15, 2020Guru - Experienced User
Try wired PC or laptop speed testing with Ooklas installable speed test app for Windows or Mac.
Randyvan
Ping 2
Download 49.21
Upload 2.11
- FURRYe38Aug 16, 2020Guru - Experienced User
- RandyvanAug 17, 2020Aspirant
I contacted my internet provider and they told me I was directly hooked to fibre and they did not ahve a modem.
So then I had them compare my settings to what I was paying for and they found out I was not getting the service I was paying for. They reset and now my speeds are as follows:
Download: 142.86 Mbps
Upload: 16.2 Mbps
Much better and my router is working well.
We are all good now and thanks for your help.
- FURRYe38Aug 17, 2020Guru - Experienced User
Thanks for letting us know.
Enjoy. :smileywink:
