joe43wv
Sep 07, 2021Aspirant
RBR50v2 Dropping Connection
For the last week my RBR50v2 keeps dropping internet for no known reason. I have one satellite connected and the signal strength is strong. I've read through the forums and it appears this is a known...
joe43wv
Sep 24, 2021Aspirant
UPDATE: The Satellite is about 45' away from the base station, shows Good 5Ghz Strength on the dashboard. I've tried all of the settings you recommended and the issue has gotten worse. Are there any other solutions to try before contacting support for a replacement unit?
Sep 24, 2021Guru - Experienced User
Is the top ring on the RBR turning on when this happens? if so, what color is it?
Do both wired and wireless devices loose connection?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- joe43wvSep 24, 2021Aspirant
I turned off the auto channels and it actually made the issue worse. I'm going to perform a factory reset to see if that resolves the issue. Will update with results.
- FURRYe38Sep 24, 2021Guru - Experienced User
OK. Please give feedback to the question presented. Helps us out.
