joe43wv
Sep 07, 2021Aspirant
RBR50v2 Dropping Connection
For the last week my RBR50v2 keeps dropping internet for no known reason. I have one satellite connected and the signal strength is strong. I've read through the forums and it appears this is a known...
Oct 14, 2021Guru - Experienced User
Is the top ring on the RBR turning on when this happens? if so, what color is it?
Do both wired and wireless devices loose connection?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
joe43wv
Oct 15, 2021Aspirant
I've tried two different modems with two different ISP. One Arris modem on Suddenlink Cable and one Netgear modem on Frontier DSL. The oval ring on the satellite turns amber, the oval ring on the main router doesn't change color, just dark, however the power light on the back is still green. Both wired and wireless devices lose connection. The wireless SSID disappears and the hard wired connections won't even receive DHCP addresses. I've tried both auto and manual settings before and nothing changes.
- FURRYe38Oct 16, 2021Guru - Experienced User
Can you verify that the RBR has same FW version loaded as the RBR?
