ron111157
Jan 13, 2021Apprentice
RBR50V2. firmware update issues
I have a RBR50V2 router 1 RBS50V2 satellite 1 RBS50 satellite Currenty have version 2.5.2.4 on all Tried a online update and got "no new firmware version available". however.... the web site s...
- Jan 13, 2021
Ok after a long tedious process I am updated to version 2.7.2.102 !!
First. The Orbi is retail and in Router mode
I use Apple and either a Chrome and/or Safari browser.
problem #1 a brainfart
When I downloaded the firmware update I did not realize a separate file was embedded in the release notes. One for the router and one for the satellite. My bad
problem #2
Once I knew that i manually updated (satellite, satellite, router) twice. One for each or the previous updates until I was current with 2.1.7.60. a loooong process! Then the system notified me the latest update was available and I was able to online update it. Now I'm current.
Of course this made the system a little unstable. Satellites dropping in and out and several items yet to be discovered. I am confident with a little time it will settle and be fine.
One thing I did notice was for a short time the Satellites were daisy chaining back to the router. Is that a new feature? In the past each satellite always connected to the router direct.
Never satellite-to-satellite-to-router.
Thanks for the help!
Jan 13, 2021Guru - Experienced User
Sometimes NG doesn't put some versions up on there auto update servers so sometimes you have to check the NG support page.
You can manually download and manually update FW to v60 if you wish using a wired PC and web browser.
FYI, v2.7.x versions are for only US region users.
