ron111157
Jan 13, 2021Apprentice
RBR50V2. firmware update issues
I have a RBR50V2 router 1 RBS50V2 satellite 1 RBS50 satellite Currenty have version 2.5.2.4 on all Tried a online update and got "no new firmware version available". however.... the web site s...
- Jan 13, 2021
Ok after a long tedious process I am updated to version 2.7.2.102 !!
First. The Orbi is retail and in Router mode
I use Apple and either a Chrome and/or Safari browser.
problem #1 a brainfart
When I downloaded the firmware update I did not realize a separate file was embedded in the release notes. One for the router and one for the satellite. My bad
problem #2
Once I knew that i manually updated (satellite, satellite, router) twice. One for each or the previous updates until I was current with 2.1.7.60. a loooong process! Then the system notified me the latest update was available and I was able to online update it. Now I'm current.
Of course this made the system a little unstable. Satellites dropping in and out and several items yet to be discovered. I am confident with a little time it will settle and be fine.
One thing I did notice was for a short time the Satellites were daisy chaining back to the router. Is that a new feature? In the past each satellite always connected to the router direct.
Never satellite-to-satellite-to-router.
Thanks for the help!
Jan 13, 2021Guru - Experienced User
Is your Orbi a Retail unit or possible something you got from an ISP?
What browser are you using? Try IE11, Edge for Firefox.
ron111157
problem #2
- FURRYe38Jan 13, 2021Guru - Experienced User
Glad you got it working.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Be sure to make a back up configuration to file for safe keeping. Helps save time if a reset is needed.
Enjoy. :smileywink:
ron111157 wrote:Ok after a long tedious process I am updated to version 2.7.2.102 !!
problem #2
- vajimJan 14, 2021Master
I'm glad you had a positive experience
