Azrael90's avatar
Azrael90
RBR50v2 Flashing white Router Ring
After moving my network hardware to a new room (Orbi RBR50v2 and modem) I noticed that the ring LED was continuing to pulse white when it was starting up, and I did not have an internet connection on...
  • Azrael90's avatar
    Azrael90
    Dec 03, 2021
    I will first start off by stating that my router has finally been set back to factory settings.  This morning before I left for work I had plugged the power back into the router and once it had started up I held the reset button until the power LED started to blink the amber color.  I then stopped pressing the button and left for work.  Upon returning home I noticed the top ring LED was solid white and I was able to connect to the router and reconfigure it.  I guess it just needed a longer time (more than the 10+ minutes I waited before) to go through its process of factory resetting itself.  Weird, but I'll take it.
    To answer your questions, even though not needed but to provide context:
    Current firmware is V2.7.3.22
    The modem is a Motorola - MB7621
    Yes, a power cycle has been done since the last update.
    I did try this power sequence last night, and that is the normal procedure I follow when restarting my modem and router.
