AHF
May 30, 2020Aspirant
RBR50v2_ Loses Internet connection
Hi, I need help. I have over 3 months having problems with my new router. It loses internet connection several times in a day and the only way to get the service back is un-pluging the Modem. My mo...
May 31, 2020Guru - Experienced User
1. what modem is it?
2. Firmware on the rbr?
- AHFMay 31, 2020AspirantModel is a Frontier Communication Modem
MODEL # FOG420 FTRO8A00FC1C
FIRMWARE in Router and Satellites 2.5.1.16
Thanks- FURRYe38May 31, 2020Guru - Experienced User
Has the ONT and RBR been powered OFF for 1 minute then back ON?
Has a factory reset and setup from scratch been performed since last update?
- AHFMay 31, 2020AspirantHi,
Yes, they have powered off for over s minute and they back on.
Yes, I have done a factory reset and updated the firmware several times and the problem persists.
Thanks
