aninkling
Mar 19, 2022Aspirant
rbr50v2 loses internet periodically after install of v 2.7.3.22
I just installed firmware version 2.7.3.22. Since then, my router stays connected to the internet for about 1/2 hour and then drops the internet. I have to restart the router to get the internet back. It is dropped again in 1/2 hour. And repeat. The following is the log. Note that the router internet service was down overnight. I redownloaded and manually reinstalled the same firmware version about 8:15 this morning. I had reset the router to get internet service about 08:00. The fact that I got those DoS Attacks makes no sense, since the internet service was down overnight.
The log: [admin login] from source 192.168.1.2, Saturday, March 19, 2022 07:28:05
[DoS Attack: Ping Sweep] from source: 61.135.214.54, Saturday, March 19, 2022 07:26:21
[DoS Attack: WinNuke Attack] from source: 58.218.35.222, port 60111, Saturday, March 19, 2022 07:12:42
[DoS Attack: TCP/UDP Echo] from source: 106.75.165.127, port 58914, Saturday, March 19, 2022 07:12:32
[admin login] from source 192.168.1.2, Saturday, March 19, 2022 07:11:29
[DHCP IP: 192.168.1.10] to MAC address 4a:f1:01:xx:xx:xx, Saturday, March 19, 2022 07:10:27
[DHCP IP: 192.168.1.6] to MAC address ac:e2:d3:xx:xx:xx, Saturday, March 19, 2022 07:10:22
[Time synchronized with NTP server] Saturday, March 19, 2022 07:10:21
[DHCP IP: 192.168.1.4] to MAC address ec:0d:e4:xx:xx:xx, Saturday, March 19, 2022 07:10:16
[DHCP IP: 192.168.1.3] to MAC address f0:27:2d:xx:xx:xx, Saturday, March 19, 2022 07:10:07
[DHCP IP: 192.168.1.7] to MAC address 00:e9:3a:xx:xx:xx, Saturday, March 19, 2022 07:10:05
[DHCP IP: 192.168.1.5] to MAC address 00:71:47:xx:xx:xx, Saturday, March 19, 2022 07:10:04
[DHCP IP: 192.168.1.9] to MAC address c4:ac:59:xx:xx:xx, Saturday, March 19, 2022 07:10:03
[Internet connected] IP address: 47.37.192.20, Saturday, March 19, 2022 07:09:35
[Initialized, firmware version: V2.7.3.22] Saturday, March 19, 2022 07:09:31
Sort By
I'd do a whois lookup on those IP addresses that are incoming on the WAN side and see where there coming from.
I would avoid posting private device MAC addresses in public forums as well.
- aninklingAspirant
I had to pay for a subscription ticket and worked about 6 hours after to find the solution. The problem was the old firmware and the new firmware were not compatible, so all the inherited router settings where just random data to the new firmware. There certainly should have been a warning that such a situation existed, and the software installer should have caught it. I consider this the worst possible outcome of support a technical company can have: releasing incompatible firmware and then charging an arm and a leg to tell the customer so... And that the solution was a hard reset and start the entire house configuration from scratch. One key issue for me is that in the old firmware I could set 2.4 and 5 as separate SSIDs, in the new software the SSID is the same. Another issue was the satellite had some problems. So a 3 day bummer for failure of Netgear support and my out of pocket cost.
What did they mean my saying that old and new FW were not compatible?
Orbi has never been able to separate SSIDs nor is it supported by NG.
