aslaninteriors
Jul 14, 2021Follower
RBR50v2 Orbi - Windows "Connected No Internet" with Killer 1550i wireless adapter, problem with Mac
Hi all, I'm having serious trouble with my Windows 10 Lenovo laptop with a Killer 1550i wifi adapter...I will be connected fine for hours on end, then all of a sudden internet cuts out and I get ...
Jul 14, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Do wired devices have any problems?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Be sure your Wifi adapter drivers are up to date...
