Bhalil55
Apr 17, 2020Follower
Rbr50v2 Problems getting online. It say I'm connected but my phone ,Xbox one, can't connect.
Bedroom
Apr 17, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
- Retired_MemberApr 17, 2020
No copy pasting please
- BoilerPlateApr 17, 2020Apprentice
Don't tell others what do to please. This isn't your forum.
If you have a problem with users, you should contact netgear forum support.
BoilerPlate wrote:Don't tell others what do to please. This isn't your forum.
Never claimed it was. Haven't we met before?
Forum support is fully aware of your friends faulty advice and they choose to turn their heads. That might because he's a moderator wannabe in cognito
