Bhalil55
Apr 17, 2020Follower
Rbr50v2 Problems getting online. It say I'm connected but my phone ,Xbox one, can't connect.
Bedroom
Apr 17, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Retired_Member
Apr 17, 2020No copy pasting please
- BoilerPlateApr 17, 2020Apprentice
Don't tell others what do to please. This isn't your forum.
If you have a problem with users, you should contact netgear forum support.
- Retired_MemberApr 17, 2020
BoilerPlate wrote:Don't tell others what do to please. This isn't your forum.
Never claimed it was. Haven't we met before?
Forum support is fully aware of your friends faulty advice and they choose to turn their heads. That might because he's a moderator wannabe in cognito
By you trolling and givng demanding information, you try to make it yours which is bad. Might try helping out others instead of trolling and badgering users. Netgear is already aware of your public history. It's telling for sure. It shows everyone just how much you don't know or really care about anything.
I'd advise users not to take VAJim information to heart. it is as he says "false" at best. It's a shame he can't be more helpful towards the community and users. This is not what the community forum is about or here for.
No back to the program.
