simont1981
Aug 08, 2022Tutor
RBR50v2 Satellite network ports disconnect
Good evening folks, Apologies for posting for help on my first post - but Netgear isn't offering support on an Orbi system that is less than a year old, and only provides me with a link to this f...
Aug 09, 2022Guru - Experienced User
What actual modem/gateway do you have from your isp?
I know you said you have everything disabled but how do you actually have it setup? In passthrough mode? with the netgears IP address in its dmz?
I'm a fan of pihole but I've occasionally had issues with it.
Have you tried (temporarily) setting the router to use the ISP's dns (or google/cloudfare's) for both IPv4/6 to see if its some issue with the pihole? The pihole doesn't do the best job when its an intermittent issue.
- simont1981Aug 09, 2022TutorIt's the THG3000v2 from Vodafone on a 500 Meg line - the DMZ is configured for the IP of the Orbi base, all the Wireless and Firewall settings are disabled on the ISP kit and it's been fine for the last 8 months.
I set my affected devices to wireless last night and when the LAN ports dropped out, I thankfully still had Internet access on them - eventually I unplugged the Ethernet cables though, as the regular popups were annoying me. The odd thing is that I went from getting the issue a handful of times in a week, to numerous times in under an hour yesterday.
I've not touched PiHole to be honest, as the Wireless is working fine, and all that traffic still goes via the Pi - I will try it of course, but highly doubt it will help. I'm thinking a factory reset is the way to go - but I'd prefer to at least get a handle on the issue, so I don't have to factory reset every 10 months (about the length of time I've been with Orbi).- plemansAug 09, 2022Guru - Experienced User
Sounds like it could be backhaul related but I'd still try the pihole option. I ran into issues when one specific device was sending to frequent of requests and was running over the limits and the pihole would lock up for short periods. Good thing is there isn't anything to change on the phole, just change the settings on the router and test it. If it doesn't work, you were planning on factory resetting anyway.
- JeffgearAug 10, 2022Virtuoso
I would be surprised if a DNS or backhaul issue were causing the TV and PS to think their Ethernet cables had been physically disconnected, I'd expect to see a different error type like "no internet" or "unable to resolve...". I'd be inclined to think it was hardware or power issue with that satellite but you've tried swapping satellites so it's unlikely to be two intermittent and identical satellite hardware issues. Did you a swap their power adaptors as well or did you keep to the original satellite's adapter? Is the main power strip or socket the adapter is plugged into dodgy? Are the Ethernet cables decent and how long are they? I'm assuming the satellite is not on the fringe.
Then:I'd be tempted to go back to basics. One satellite with the TV or PS only connected, no PI in the loop anywhere. See if that's stable. If it is, add the other satellite. If that's stable then add the PS. If that's stable, add the PI...
