simont1981
Aug 08, 2022Tutor
RBR50v2 Satellite network ports disconnect
Good evening folks, Apologies for posting for help on my first post - but Netgear isn't offering support on an Orbi system that is less than a year old, and only provides me with a link to this f...
Jeffgear
Aug 10, 2022Virtuoso
I would be surprised if a DNS or backhaul issue were causing the TV and PS to think their Ethernet cables had been physically disconnected, I'd expect to see a different error type like "no internet" or "unable to resolve...". I'd be inclined to think it was hardware or power issue with that satellite but you've tried swapping satellites so it's unlikely to be two intermittent and identical satellite hardware issues. Did you a swap their power adaptors as well or did you keep to the original satellite's adapter? Is the main power strip or socket the adapter is plugged into dodgy? Are the Ethernet cables decent and how long are they? I'm assuming the satellite is not on the fringe.
Then:
I'd be tempted to go back to basics. One satellite with the TV or PS only connected, no PI in the loop anywhere. See if that's stable. If it is, add the other satellite. If that's stable then add the PS. If that's stable, add the PI...
simont1981
Aug 11, 2022Tutor
Thanks to CrimpOn plemans Jeffgear for taking time out to assist me with this.
Well, yesterday I factory reset everything - in the course of fiddling, I decided to limit the DHCP scope on the Orbi (not related to this posted fault) - but for some unknown reason after doing so, nothing would get an IP from DHCP afterwards... even though the settings were fine/enabled and I tried release/renew/flush/register.
I digress.
So - *touch wood* I have yet to see the LAN ports on any devices drop like before, though I have now probably jinxed myself typing that (!!), so time will tell I guess...
I will certainly post back here if the issue arises again, as it may at least serve to assist someone else with the fault - but [presently] I am hopeful that whatever was wrong, has been wiped away from a factory reset.
Many thanks chaps - with all due respect, I hope I won't be back here moaning about my Orbi again đ
