DebF
May 07, 2020Aspirant
RBR50v2 setting up says check ethernet cable
set up stops at check ethernet cable-- have tried different cable retry same result using Netgear ATT wireless modem to connect to could modem type be problem really asking how to set up I am foll...
May 07, 2020Guru - Experienced User
If the ISP modem already has a wifi router built in, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
The modem maybe using same IP address of 192.168.1.1 which the netgear orbi uses as well. You should be able to factory reset the RBR and walk thru the setup wizard and it should change the IP address to something else if this is the case.
- DebFMay 08, 2020Aspirant
thanks for response
Modem I am connecting Orbi to
NETGEAR
Model: MR1 100
thank you
- FURRYe38May 08, 2020Guru - Experienced User
The mobile router already has built in router. You may want to change to AP mode.
Be sure to swap out LAN cables in between the MR1 and RBR. CAT6 is recommended.
DebF wrote:thanks for response
NETGEAR
Model: MR1 100
thank you
thanks for response now at new roadblock
When attempting to log into my ATT Netgear Model: MR1100, using a browser - http://192.168.1.1 or http://attwifimanager, or the Netgear App, using the credentials, located on the inside of the router, of “attadmin”, and password, I can not log into the router. Each login page comes preloaded with user name “admin” and I can not change it. How can I log into the MR1100 if I can’t enter the credentials located inside the router?
