DebF
May 07, 2020Aspirant
RBR50v2 setting up says check ethernet cable
set up stops at check ethernet cable-- have tried different cable retry same result using Netgear ATT wireless modem to connect to could modem type be problem really asking how to set up I am foll...
DebF
May 08, 2020Aspirant
thanks for response
Modem I am connecting Orbi to
NETGEAR
Model: MR1 100
thank you
May 08, 2020Guru - Experienced User
The mobile router already has built in router. You may want to change to AP mode.
Be sure to swap out LAN cables in between the MR1 and RBR. CAT6 is recommended.
DebF wrote:thanks for response
NETGEAR
Model: MR1 100
thank you
- DebFMay 08, 2020Aspirant
thanks for response now at new roadblock
When attempting to log into my ATT Netgear Model: MR1100, using a browser - http://192.168.1.1 or http://attwifimanager, or the Netgear App, using the credentials, located on the inside of the router, of “attadmin”, and password, I can not log into the router. Each login page comes preloaded with user name “admin” and I can not change it. How can I log into the MR1100 if I can’t enter the credentials located inside the router?
- FURRYe38May 11, 2020Guru - Experienced User
Please review the user manual and information regarding your mobile router.
Turn OFF the Orbi system while working with the mobile router.
DebF wrote:thanks for response now at new roadblock
