TC10
Feb 15, 2021Tutor
RBR50v2 upgraded to V2.7.2.104 - now RBR50 is pulsing white
Feb 13, 2021 I upgraded my RBR50v2 to V2.7.2.104 yesterday. It is now pulsing white though seems to be working at least partially. My RBS satellitle is not sowing lights and seems to be working. ...
Feb 15, 2021Guru - Experienced User
Have you powered OFF the ISP Modem and RBR for 30 seconds then back on with the modem first, then the RBR?
How was the system updated? Orbi app or thru the RBRs web page?
TC10
Feb 15, 2021Tutor
My ISP Modem is Hitron Model CGNM2250
It was updated by the Orbi App.
I will try the 30 seconds off for bot devices. I did try turning off the RBR50 for a minute.
- FURRYe38Feb 15, 2021Guru - Experienced User
Let us know know it goes.
Seen others having some problems after updating with Orbi app recently.
TC10 wrote:My ISP Modem is Hitron Model CGNM2250
I will try the 30 seconds off for bot devices. I did try turning off the RBR50 for a minute.- TC10Feb 15, 2021Tutor
I did the power off of my modem and RBR50. I then brought modem back up and made sure it was working ok. I then reconnected my RBR50. The RBR50 did similar pulsing white and then went to solid magenta. It still seems to be working ok as does the satellite RBRS50?? but solid magenta on the RBR50. ... hmmm
It shows as fine on te orbi broswer and orbi app.
bu solid magenta.
Try walking thru the setup wizard with a PC and web browser on the RBR...
