plblythe
Aug 17, 2023Aspirant
RBR50V2 won't allow my Blink 2 module to connect
I have worked with Blink to replace my Module 2 twice. My original Module disconnected in the middle of the night and I haven't been able to connect the newer two that Blink sent me since then. Blink...
CrimpOn
Aug 18, 2023Guru - Experienced User
It might be useful to eliminate Access Control from the picture in order to diagnose the issue.
(If the Blink module will not connect when Access Control is not enabled, then Access Control cannot be a factor.)
plblythe
Aug 19, 2023Aspirant
I eliminated the access control. Nope, it didn't work. I am about ready to take this whole blink setup and throw it in the trash. I have never been so frustrated with a piece of technology! Any other ideas?
- michaelkenwardAug 19, 2023Guru - Experienced User
What does this blink thing do?
I ask because a search for "blink" is useless. Too many false positives.
Search - NETGEAR Communities – blink
Add something to narrow down the search and you might get somewhere
- plblytheAug 19, 2023Aspirantblink is an Amazon company that makes video doorbells and something called a Blink Module 2. I’ve owned this system for about seven months and it worked great until about a month and a half to two months ago when it stopped working in the middle of the night. Blink/Amazon has replaced this module twice and I’m still having the issues. It keeps asking to connect to the Blink Wi-Fi and this is a normal procedure. Once it connects to their Wi-Fi, it allows me to redirect it to my Wi-Fi. And yes I do love my Orbi. It works great.
- CrimpOnAug 19, 2023Guru - Experienced User
That video seems pretty clear. At which point does it fail?
I would be tempted to start over. i.e.
- Delete and re-install the Blink app on the phone.
- Create a new Blink account.
- Add the module to the new account as per the instructions
- plblytheAug 19, 2023AspirantWhile working with the Blink folks I've done this at least 10 times. Any other ideas?
plblythe wrote:
While working with the Blink folks I've done this at least 10 times. Any other ideas?I still do not understand where during the process it fails. (I already have too many brands of WiFi cameras to install a Blink, so I have no personal experience with this product.) Is there some error message?
Is there another device that can be used to configure the Blink module? i.e. load their software app on something else, create a new Blink account, add the Blink module to that account.
