krothk
Jun 19, 2021Aspirant
RBR50v2/RBS50v2 RBR accesses 5g, but RBS is running 2.4. How can I get them to both run 5g?
Both were updated to V2.7.2.104
CrimpOn
Jun 19, 2021Guru - Experienced User
"accesses" is a bit ambiguous. Can you please describe the situation in more detail?
Both the Orbi router (RBR) and satellite( RBS) are supposed to broadcast the Orbi WiFi name (SSID) on both a 2.4G WiFi channel (1-11 in the US) and a 5G WiFi channel (36-48 in the US). Most modern WiFi clients display only the one SSID and do not indicate how many access points are broadcasting that SSID or on which channels*. After a device connects, many devices have a way to display the properties of the connection (channel, link rate, etc.)
What is the basis for concluding that the satellite is not broadcasting the 5G WiFi?
* There are software applications that will display the characteristics of every WiFi access point (signal level, channel, etc.)
For Android, I am partial to WiFi Analyzer by Kevin Yuan.
For Windows, WiFiInfoView by Nirsoft.
(both are free)
