krothk
Jun 19, 2021Aspirant
RBR50v2/RBS50v2 RBR accesses 5g, but RBS is running 2.4. How can I get them to both run 5g?
Both were updated to V2.7.2.104
Jun 19, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
krothk
I don't know how to change channels etc, can't find where to do that on the Orbi website
