OliveR5
Dec 07, 2021Aspirant
RBR750 - iOS devices fail to get IP address from Orbi + frequent disconnects
For the past 6 months or so, my Orbi RBR750 router & 2 satellites are struggling to keep iPhone & other mobile devices connected to the router. Wifi will drop serveral times during the day. Sometime...
Dec 07, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Thank you
