adolgov
Aug 09, 2021Tutor
RBR750 403 Access denied after upgrade to 4.6.3.7 firmware
I'm getting a proxy error from the router, and am unable to access its configuration page after firmware update from 3.x version to 4.6.3.7. I factory reset the router, and then I'm able to conne...
- Aug 09, 2021
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
CrimpOn
Aug 22, 2021Guru - Experienced User
adolgov wrote:
Furthermore, the web application is not allowing me to downgrade to the older firmware because the "Yes" button that is required to answer the "are you sure you want to install older firmware" is missing from the UI.
Any hints on how to get around this error or an easy way to get past the "missing Yes button" part of manually downgrading.
It appears that Netgear has removed the option to manually install older firmware on the AX series Orbi's. The forum has numerous posts expressing frustration that once an AX firmware gets updated, there is no going back. I may have missed something, but I do not recall anyone sharing a method to get around this.
