costler's avatar
costler
Tutor
Nov 17, 2021
RBR750 Blocked Devices
RBR750 firmware version 4.6.5.14, purchased Sep 1st.
My Orbi configuration:
1. RBR750 with 2 satellites
2. The router and the satellites are connected via Ethernet Backhaul
3. The main router and one of the satellites connected to external 1G switches so I can have a few devices connected by wire.
4. WAN port connects to my Netgear cable router. The RBR750 is the default NAT and DHCP server for most devices.
The first week I had issues with ALL of my network devices being blocked. It was a combination of Parental Controls and Access Controls.  Neither of which I need, after a bit of fustration, factory reset and so forth, I got everything working.  Parental Controls and Access Controls are both turned OFF.  Just this week Parental Controls in the phone app changed and shows "Expired - Off"
I can connect to my Orbi and the two satellites via the android app.  The devices in question have green dots showing online.  However, I cannot connect to any of the devices, all home automation things from different companies; for what it's worh they have all worked for years, until Orbi.
I have rebooted a couple of times.  I can connect via the phone app from Arizona so I know the internet works.  How do I unblock my devices remotely?  If I have to fly to michigan to fix this I am going to be a very unhappy person.  This equipment should be better than this.
