MalcolmI
Nov 05, 2021Tutor
RBR750 in AP Mode on same network?
Help. Its such a shame my RBR750 and it’s 3 Satellites are about to be returned. They seem so good at wifi! And support have spent over an hour or so going through what I have already tried. I bou...
- Nov 05, 2021
Yes Orbi in AP mode and I have aded two of the Satelites - one more to go.
Didnt really want the main Orbi in the comms cabinet, but can live with that - may need to buy a 4th Satelite - see how we go,.
So again thanks.
MalcolmI
Nov 05, 2021Tutor
Sorry - the OpenReach is just a modem with no configuration options. It is old but everything works, apart from the Orbi.
Nov 05, 2021Guru - Experienced User
do you have its model number?
Did you ever try factory resetting the vigor?
starting back from stock with everything?
