K0mpir
Aug 10, 2021Follower
RBR750 Keeps disconnecting
Hello, I have annoying problem with this system the coverage itself in the house is good (router plus 2 satellites) it's attached to a tplink 4g modem via cable but randomly its gets disconnected th...
Aug 10, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
