DrBen
Aug 12, 2021Follower
rbr750 network password chaange
RBK750 Orbi I would like to change the network password without changing it on every connected deice. Is that possible?
Aug 12, 2021Guru - Experienced User
No. if you change the password to access the network, then all those connected devices need to have theirs changed as well so they can access it.
