shredhead1260
Feb 01, 2022Tutor
Rbr750 no connections about once a month
Weird problem... about once a month, nothing on the network will have internet access but the unit speed tests fine, and the only remedy is to reboot the router. This is annoying, but I'd be ok with setting the router to reboot once a month somehow. This ability does not exist however. Has anyone seen this? Is there a fix? Yes I have the latest firmware.
the "latest' isnt' always.
What version are you on?
did you try this version
- Yeah I’ve run into that before. I had an issue that I never was able to fix, all sorts of extra devices showing up on the device list that were not there. I figured the developers left a bunch of test devices there and didn’t clean them up before releasing the firmware.
Anyway, with no release notes it would be hard to update to a new version. What does it fix?- plemansGuru - Experienced User
Not exactly sure as it isn't "officially" released yet but I did install it to my RBK752 kit and its been more stable since.
