shredhead1260
Feb 01, 2022Tutor
Rbr750 satellites interfering with each other
Ended up unplugging one of the satellites, I was having interference/confusion which led to poor performance (I assume a loop was created). I suspected they were too close to each other and in the en...
Feb 01, 2022Guru - Experienced User
Are you using wired or wireless backhaul?
I've found it tolerates being to close better if using a wired backhaul.
Otherwise with a wireless backhaul, it needs at least 30 ft between units.
- shredhead1260Feb 02, 2022TutorWireless backhaul, and no decent way to run wires. I’ve tried different locations for the satellites too. I’m not sure if it was 30 feet though like I said the house is huge. At this point the coverage seems ok so I’ll stay with just one satellite which is sort of in the middle of the house on floor 2 while the router is below ground somewhat below that.
