Kelsett
Apr 24, 2020Tutor
RBR850 NAT loopback
Hello, I'm hosting a webserver at home. The site is perfectly accessible from outside the network. When I try to access it from inside the network, it works via wifi but won't work on an ethe...
Retired_Member
Apr 24, 2020
Kelsett wrote:Hello,
When I try to access it from inside the network, it works via wifi but won't work on an ethernet connection. I tried this on multiple devices.
Somehow NAT loopback is broken on ethernet only. Is there some setting somewhere for fixing this ?
Thanks !
you may want to post this over on the Orbi (AX) group
- KelsettApr 24, 2020Tutor
Done ! https://community.netgear.com/t5/Orbi-AX/RBR850-NAT-loopback/m-p/1900560#M3171
Thanks and sorry for the double post, this one can be closed.
