scanlont
Dec 17, 2020Aspirant
RBR850 Schedule blocks services, but does not unblock.
My Orbi RBR850 will turn on blocking services for my son's xbox at the time scheduled to block services every night at 10:00. But it will keep blocking them in perpetuity and not unblock them at the...
CrimpOn
Dec 17, 2020Guru - Experienced User
scanlont wrote:My Orbi RBR850 will turn on blocking services for my son's xbox at the time scheduled to block services every night at 10:00. But it will keep blocking them in perpetuity and not unblock them at the scheduled time at 7 am every morning. It's driving me nuts and I can't find an answer
It's probably worth mentioning that Netgear set up a separate community forum for the "AX" WiFi products. If the question is posted there, people who actually own the AX products will be more likely to have experience with this situation:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
That said, I notice that the "Schedule defaults to Start 0:00 and End 24:00 (before the user inputs times).
Can you try this experiment: Set the Start time to something reasonable, such as 22:00 (10pm) and set the End time to 23:55 (11:45 at night). Yes, I understand that this does not accomplish the desired result. I wonder, however, if there is a logic flaw in Netgear's implementation which is not as smart as the "dumbest" smart plug that I own.
There may very well be a good reason that Netgear partnered with Disney Circle to provide "Parental Controls" (and later apparently "rolled their own" Parental Controls).
