sbernardnc
Sep 13, 2021Tutor
RBR850, unable to sync satellites
I have an RBR850 system with 2 satellites. Firmware Version: V3.2.18.1_1.4.14, Router is connected by ethernet to main computer. Previously both satellites were detected and synced. I have not...
CrimpOn
Sep 13, 2021Guru - Experienced User
Router is connected by ethernet to main computer. Previously both satellites were detected and synced. I have not changed any default settings except to rename the system using the old SSID and password which was done when purchased 9 mos ago.
This summer, I turned off the system twice while away and once while changing out the backup battery.
When I plug in each satellite, the blue light appears for 3-4 minutes and they are detected on the orbilogin site. I am unable to sync them and they dont show up on the orbi mobile app. I have powered down entire system incl modem x 3, booted the router x4, reset and powered up x 2, added the satellites x 6. I have turned off the firewall once without any effect. Any suggestions? Thanks.
How do these satellites appear on the Orbi Attached Devices page? (as Satellites or..... something else?)
Once a satellite has been sync'd to the router, it does not have to go through that process again, even if it has been powered off.
I assume that backup battery refers to a UPS that powers the Orbi router?
