miller1975
Sep 28, 2021Tutor
RBR850 wont connect to satellite in AP mode
I have an RBR850 & RBS850 configured in AP mode and I am having some issue When I check for new firmware it tells me there is no internet access so I manually upgrade (when I remember) I have...
Sep 28, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
miller1975
Sep 28, 2021Tutor
Thanks for that I will ask there
- FURRYe38Sep 28, 2021Guru - Experienced User
