nannapuddin
Jul 29, 2018Follower
rbrk 40 satellites swapping
having an orbi router with 2 satilites some things connect to the furthest satilite rather than the closest one
wifi signal stuggles when it swaps connections from close to far
1 Reply
What FW are you using on the system?
Whats the distance between the router and these satellites? Feet? 30 feet is recommended to begin with.
Whats the SqFt of your home?
Try disabling MIMO, Daisy Chaing and Fast Roaming on the router then reboot the router and satellites.
Set manual channel 1, 6 or 11 on 2.4Ghz.
