KevinLiT
May 12, 2022NETGEAR Moderator
RBR/RBS 10 and RBK 12/13/14/15 Firmware Version 2.7.4.24 Released
New Features and Enhancements: Admin password brute force attack prevention Admin password strength enforcement EU data analytics opt-out Bug Fixes: Fixes the issue where the backup config fi...
old586whizz
May 16, 2022Aspirant
I've checked the firmware update section in the router and it's still not appearing as an automatic update.
Is this required to be manual?
... If so - why? Doesn't that mean that a security update won't be applied to so many routers out there?
Old586whizz
KevinLiT
May 16, 2022NETGEAR Moderator
Hi Old586whizz,
The customer is not required to update their Orbi system manually. Updates are pushed out incrementally to ensure user and network compatibility. Downloading the software manually once it is available will enable the user to get the update before it is automatically pushed out. Eventually, every person with one of these systems will be notified of the latest update through the Orbi app or the web GUI.
Let me know if you have any additional questions!!
Best,
Kevin
Community Team
- old586whizzJun 07, 2022AspirantAlmost 1 month later and the automatic firmware checker still didn't show up... For something that specifically mentions "security" patching..
I had to download the files manually and upload them.
Also, your RBS links above (and in all the other pages) point to the OLD 2.7.3.x firmware version instead of the newer one.. So I had to change those manually to even download the proper version of the firmware!!
Old586whizz
