pablohoney
Jul 02, 2021Luminary
RBR/RBS 50 firmware 2.7.3.22
New firmware is incoming this week I have been told. No release notes details yet but may fix either device list issues or link rate issue. Keep an eye on https://www.netgear.com/support/product/RBK50...
spewak
Jul 04, 2021Luminary
You know pablo,
at this point, I think I will wait this one out. I normally will not wait for the firmware auto update cycle and instead will opt for manual install. Not so anymore. Router and sat. working well.
wimmme
Jul 05, 2021Tutor
spewak And on what version are you running ? I 'm on 2.7.2.104, running pretty stable on RBR50 and RBS50, but not on my RBS50Y ...
- polomoralesJul 27, 2021Aspirant
HELP!, mY RBR50 and 4 RBS50 updated to 2.7.3.22 and now no device will stay on the network. How do I roll back to the previous version 104? It was solid?
- FURRYe38Jul 27, 2021Guru - Experienced User
Try a factory reset and setup from scratch:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQBeen working solid for me:
polomorales wrote:HELP!, mY RBR50 and 4 RBS50 updated to 2.7.3.22 and now no device will stay on the network. How do I roll back to the previous version 104? It was solid?
- MagistusJul 30, 2021Aspirant
Same. I went onto the application on my phone, did the mandatory restart, and now my internet speeds have dropped and my internet drops constantly. What can I do in order to fix this? Or do I have to do a rollback of firmware versions?
- FURRYe38Jul 30, 2021Guru - Experienced User
Magistus wrote:Same. I went onto the application on my phone, did the mandatory restart, and now my internet speeds have dropped and my internet drops constantly. What can I do in order to fix this? Or do I have to do a rollback of firmware versions?
- nicholbJul 30, 2021Luminary
Go to this page and hit the + by "view previous versions". Download .104 and install manually. You may also need to do a factory reset and manual setup afterward. Just downgrading did not resolve the issue on mine.
